Author Topic: Mk2 throttle body connector...whats this, whatsit dooo........?  (Read 3278 times)
Offline hennoir
Hi guys.....Here i go again, Mk2 16v lump.....
Hopefully you can read whats in the picture below but just in case have added text underneath aswell......
When this connector is connected the car ticks over fine.... but when you blip the throttle it seems to choke itself and then dies! It wont start then, but if you disconnect it, it will start again fine. It hunts a little but timing has been checked and is fine....
This microswitch seems to affect the above.....what is it called? and is there any easy fix?
Cheers folks
Chris (Hennoir)
Offline hennoir
Oh yeah - It's a KR lump if that make any difference....but you guys already new that  :wink:
Chris (Hennoir)
Offline bodga
  • F reg GTI 16v
I think it has somthing to do with the idle stabilisation valve stuff, check your three temp senders on the r/h side of the head, two of them control the tickover, one is for your temp gauge.
Also there is a valve and stuff on the back of the meter head that might cause you some trouble
Offline hennoir
Chris (Hennoir)
Offline pigbladder
that switch tells the idle system when the throttle is closed /open
kinda sounds like the switch is busted or gummed up so the engine thinks its idleing when it isnt
listen if its clicking every time you move the thrott , if it is check with the multimeter that its working
Offline hennoir
Bang on - Turns out the idle switch was wired back to front hence not running when connected, its not an original part and they are according to a local garage now obsolete, so it's now been rewired and runs sweet as a nut......
Cheers guys
Chris (Hennoir)
