Author Topic: gear linkage and bushes kit  (Read 16784 times)
Offline grandpa erb
« on: 25 June 2011, 16:01 »
can anyone reccomend somewhere i can pick up one of these?
thanks in advance
erb
Offline sharki786
  • GOT BOOST??
Re: gear linkage and bushes kit
« Reply #1 on: 25 June 2011, 16:03 »
try egay to start of with, deemon tweeks and google
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline benvictors
  • bgk Tuning - coming soon!!!
« Reply #2 on: 25 June 2011, 17:43 »
Why do you want em, as in wahts the issue with your gears?
The reason I ask is, if you can find gears but when in gear its very sloppy back and forth then I can make you a new bush up that can be fitted in 5 minutes for 5 whole english pounds delivered, Shady will be fitting one I sent him tomorrow so we can await his opinion on siad item  :cool:
Offline harlemex
« Reply #3 on: 25 June 2011, 18:47 »
That sounds interesting. I replaced the linkage on mine but it is still sloppy. Which part do you make?
Offline benvictors
« Reply #4 on: 25 June 2011, 19:04 »
On the end of gear rod there is a 'U' bracket that a bush sits in, these bushes are sh!te and wear down and dissintegrate, this is what governs how tight your gears feel when in gear (Back to front) I replaced mine because I had about 2" back n forth travel when in gear, put my newly designed solid poly/graphite bush in and bang the travel is gone  :grin:
Made Kells one when he had his 8v and just made Shady one  :cool:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Offline grandpa erb
« Reply #6 on: 26 June 2011, 11:10 »
thanks for replies.
benvictor, gear selector is awful, first is tough to find, second theres a knack and fourth feels like its barely gone in and bounced out again. was thinking change linkage and bushes, shall definately keep in mind the bush you make.
Offline SquidgyB
« Reply #7 on: 21 August 2011, 20:36 »
Hope nobody minds the necro.
benvictors, are you still making those bushes? I think I need both the linkage kit and one of the bushes to get min up to scratch.
I can see when removing the gator that left-right play is purely down to the gearstick and bushings - so I'm guessing that'll be fixed with the repair kit off ebay above.
Forward-back play is another story - I can select gears ok, but to me it sounds as if the bushing on the "U" is completely gone - there's a lot of play, and a metal on metal clunking noise coming from beneath my feet at both ends of the play - I'm assuming the bush you make goes right where that play is happening!
'98 Mk3 Golf GTi 2.0 8v
Offline Shady Pioneer
  • graphic designer.
« Reply #8 on: 22 August 2011, 13:10 »
Just for the record, the bush benvictors supplied has made a world of difference. A lot more response in selecting gears, no play back and forth. :afro:
And because I'm a noob when it comes to cars, he even let me ring him and talk me through. :smiley:
Offline SquidgyB
« Reply #9 on: 22 August 2011, 14:56 »
Sounds almost too good to be true (going by my luck)!
I've sent him an email to see if he's still doing them - fingers crossed :D
