Author Topic: gear linkage and bushes kit  (Read 16778 times)
Offline SquidgyB
Re: gear linkage and bushes kit
« Reply #10 on: 24 August 2011, 10:44 »
I've located the source of the calanging noise when moving the gearstick forward and back - the bottom of the relay shaft (the rod with the plastic ball stuck on an arm which sticks 90 degrees out) has come loose from the bracket.
I've got the ebay linkage repair kit - I didn't have time to do anything last night, hopefully I can tonight. I just hope that a the new shaft will do the job... it's possible that the bracket has worn away, in which case I'll need to order one of those too.
Looks like i won't need the bushing from benvictors after all :)
'98 Mk3 Golf GTi 2.0 8v
robs mauve gti
« Reply #11 on: 29 May 2013, 18:36 »
On the end of gear rod there is a 'U' bracket that a bush sits in, these bushes are sh!te and wear down and dissintegrate, this is what governs how tight your gears feel when in gear (Back to front) I replaced mine because I had about 2" back n forth travel when in gear, put my newly designed solid poly/graphite bush in and bang the travel is gone  :grin:
Made Kells one when he had his 8v and just made Shady one  :cool:
Are you still producing these bushes? desperately need one. Rob.
Offline spudboy6
  • Just like a golf ......
« Reply #12 on: 19 October 2013, 20:55 »
X2 ???
Offline sharki786
  • GOT BOOST??
« Reply #13 on: 20 October 2013, 15:55 »
I fitted the full link with the bush. Got it from gsf for 12 i think. No more sloppyness :grin: nice and hard  :grin:
Feels alot better in my hand :grin:
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline spudboy6
« Reply #14 on: 20 October 2013, 16:29 »
I've had two of them now and one from matey on eBay they just don't seem to last very long
Offline Smiler76
« Reply #15 on: 02 January 2018, 01:01 »
Bit of a long shot but is the fella still making these bushes? Also would it fit/be the same on 97 16v?🤔 Thanks in advance 👍
Offline sharki786
  • GOT BOOST??
« Reply #16 on: 21 January 2018, 14:18 »
Anyone tried genuine from tps pr stealer?
*****MK4 GTI T*****
