Author Topic: mk2 engine transplant which ones best?  (Read 3389 times)
Offline mk2addict
« on: 25 June 2011, 15:50 »
i have a mk2 8v, its been resprayed silver polybushes interior is mint the only one thing im not happy with is the lack of speed. i want an engine that can give 170+bhp with a few mods i.e rebore,cams,ported/polished head. i will be doin/attemting to change the engine myself, so im thinkin a 1.8t might be a bit to much to take on. so thinkin maybe a tuned mk2 16v engine or an abf but not sure these can give me the power i want. i want 0-60 in high 6secs idealy. i cant find any reference to the amount of power a mk2 needs to get that kinda speed as no one seems to talk about it. i dont want to spend the time and money on the engine and not have the result i want. can anyone give me some advice on this? and which engine is best for a brave but novice diy mechanic to attemp lol.
Offline sharki786
  • GOT BOOST??
Re: mk2 engine transplant which ones best?
« Reply #1 on: 25 June 2011, 15:56 »
16abf turbo'd? light weight flywheel, bored out, cammed out, ported & polished & crossflowed (if possible)
or you can try a vr & turbo that, same as above realy. correct me if im wrong
abf will be easier to than the vr as the vr is chain driven, but if you get a vr then change the chains (you mostly will do that wont you?)
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mk2addict
« Reply #2 on: 25 June 2011, 16:05 »
thought about a vr but they are big heavy lumps, would prefer a nice lil revvy 16v i dont have buckets of money to spend so tuboin either of them isnt really an option, if i have to go for a 1.8turbo to get the performance i want i'll have to do that.
Offline mk2addict
abf mk2transplant
« Reply #3 on: 25 June 2011, 16:31 »
i've been told that an abf transplant is probably my best option. has anyone done one? which donor car should i aim to get? the only real difficulty i can see me havin is with the electrics, is it alot easier than waht im thinkin it might be?
Offline rob.043
Re: abf mk2transplant
« Reply #4 on: 25 June 2011, 17:27 »
If you use the search function in the mk2 section you should find answers to any and all questions.
It can be a straight forward conversion but there are options as to what you change etc. Have a read through some search results, here's one for starters, from the mk2 maintenance section:
http://www.golfgtiforum.co.uk/index.php?topic=176689.0
Offline rich1977
« Reply #5 on: 25 June 2011, 17:29 »
how about a 2.0 8v on carbs? or even 2.0 16v on carbs or even TBs, would get you close to the 150+ish.
0-60 time will all depend on how you can get the power down at the front wheels
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
Offline rob.043
« Reply #6 on: 25 June 2011, 17:32 »
see your other thread, an ABF is likely the best bet for you. They have 150 bhp as standard, and if you put there factory management system in you should easily see around 170 with a 4 branch exhaust manifold and a remap to suit. Very good power to wallet ratio.
« Reply #7 on: 25 June 2011, 20:00 »
Just drop a ABF in :cool:
Offline mk2addict
« Reply #8 on: 25 June 2011, 20:35 »
abf sounds like the plan the :smiley:. cheers everyone
Offline emery1990
« Reply #9 on: 26 June 2011, 19:24 »
I'd say you'd get about 160bhp, only 10hp out!
