Golf mk4
Wazzzer
Turbo Timer
Topic: Turbo Timer (Read 1994 times)
Phil_M
GTI forum regular
Turbo Timer
07 April 2005, 22:36 »
Hi All
Wanted to get a turbo timer fitted so was wondering if any of you's have one, and what is best to go for.
I have heard that the blitz is supposed to be good.
also are they difficult to fit.
Thanks for Help
GOLF 1.9T AGU TD05H 18G
http://smg.photobucket.com/albums/v218/pipmann30/GOLF%20GTI%20%20TURBO/?albumview=slideshow
Front wheel drive monster 0-60mph in under 5sec 0-100mph in 10sec
GazB
Newport Edition - aaahhhhh!AC Cobra Fast as F*@k -
Re: Turbo Timer
09 April 2005, 18:33 »
i had one, but you need to bypass the vw immobiliser when you remove the key or it will just kill the engine anyway. Ditched it in the end. New turbos don't need much cooling down anyway as they don't get as hot as older ones on the likes of rs turbos etc.
sold mine beforw fitting cause everyone said it was effort to fit and pointless
www.newportedition.com
Ryan_s3
GTI forum regular
Re: Turbo Timer
09 April 2005, 21:42 »
not sure on golf 1.8t ,but the audi s3 pumps oil around the turbo for 2 mins after shutdown,factory turbo timer.Turbos still need run down time to avoid knackered bearings.
Dizzie
Forum addict
Make friends with your fast
Re: Turbo Timer
09 April 2005, 21:47 »
if you have a clifford alarm you can wire that into the car to keep the ignition live when you remove the key and then turn the engine off after the time you set. easy to do without buying extra things. just a relay and some wire.
Mk4 Golf 150PD
Golf mk4
Wazzzer
Turbo Timer
