Author Topic: First service - ECU update?  (Read 4563 times)
Offline Hartside
« on: 25 June 2011, 11:16 »
Just had the car serviced this morning and it has noticably more instantaneous grunt from 2500 - 4000 rpm. Would they have changed the map on the ECU?
Carbon Grey 5dr GTI
Offline Buck
  • Das Auto
Re: First service - ECU update?
« Reply #1 on: 25 June 2011, 11:21 »
I know when mine went in for some warranty work they updated the ECU with the latest version (visibly I now have gear change indicator in the dash but not sure what else it changed)
Offline Keithuk
« Reply #2 on: 25 June 2011, 14:05 »
So you didn't have the digital gear indicator before then?
I asked the dealer about this when I had mine but they couldn't enable it. Someone else said they had theirs enabled after the dealer spoke with technical at Milton Keynes and they said there was an ecu software update for this. I shall have to get onto them again.
I had my first service in February and mine wasn't updated as far as I know, well the digital gear indicator still doesn't show?
« Last Edit: 25 June 2011, 14:07 by Keithuk »
2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
Offline Hartside
« Reply #3 on: 25 June 2011, 14:11 »
Mines always had the gear indicator showing since pick up. It's the throttle response that's just changed
Carbon Grey 5dr GTI
Offline Keithuk
« Reply #4 on: 25 June 2011, 19:10 »
But what year is your Carbon Grey 5dr GTI?
Offline Hartside
« Reply #5 on: 26 June 2011, 12:07 »
It's a 2010 (2011 MY), exactly 1 year old now
Carbon Grey 5dr GTI
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #6 on: 26 June 2011, 12:33 »
My GTI was serviced in late March but i have not noticed any change. Maybe theres a new ECU update since then  :undecided:
Mine always had the gearchange indicator as did the 09 GTI i went out in for a test drive in mid 2009 (I remember thinking oh just like the mk1)
I think the gear change indicator update thing was a GTD model year change iirc.
« Last Edit: 26 June 2011, 12:36 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline Buck
  • Das Auto
« Reply #7 on: 28 June 2011, 07:44 »
Hi Keith
Yes it was me!
Originally they replied "no" but persistence paid off!
Offline squirrelGTi
« Reply #8 on: 28 June 2011, 09:47 »
Mine just went in for a service and they didn't mention anything about ECU update. It was exactly a year old on the 25th June.
Gone GTi | 3dr | Manual | Carbon Grey | Xenons | Monza 18's | RCD 510 |Rear Camera | Winter Pack.
Offline AlanD
  • MK5 2.0T 16v
« Reply #9 on: 28 June 2011, 10:27 »
I hight doubt VW have adjusted your ECU to give you more power, adjust torque across the rev range of anything like that.
