Author Topic: Cutting out when cold  (Read 4814 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Cutting out when cold
« Reply #20 on: 06 July 2011, 22:58 »
Ain't it just.  :grin:
Offline Bellend
« Reply #21 on: 06 July 2011, 23:32 »
Moderator of the forum, not an expert. :rolleyes:
Does a good job so leave it.
Where all my moneys went.
Offline Shady Pioneer
  • graphic designer.
« Reply #22 on: 06 July 2011, 23:50 »
What you brown nosing for?  :grin: :kiss:
I thought Shady knew about the Relays! One of THE most common Mk3 faults! :rolleyes:
It is quite hilarious that the mk3 moderator is always posting about the most common problems  :grin: :grin:
Feck off.  :grin:
I know I ask about problems, but it shows I'm just like you lot, a normal.  :laugh: Thank for all the advice so far, gonna ring the stealers tomorrow, get them to order me those two relays.
Offline reptiles nd fishin
« Reply #23 on: 07 July 2011, 00:01 »
mines was also cutting out when cold, i just moved the throtle cable back one notch and all is fine now.
Offline Len
« Reply #24 on: 08 July 2011, 09:02 »
So what engine revs you got at tick over then?
www.sas.org.uk
www.the-ace.org.uk
« Reply #25 on: 08 July 2011, 11:14 »
When its cold and just starts i get mayby 1200 rpm for 30-40 seconds then it drops to around 950 rpm but only when its cold. if i stop the car and start it again before it cools right down it starts at around 950 rpm.
  • graphic designer.
« Reply #26 on: 08 July 2011, 18:51 »
I've now found that is only happens under braking.  :undecided:
Offline Adam
« Reply #27 on: 08 July 2011, 19:06 »
Vacuum line from manifold to the break servo?
Down Hill From Here.
« Reply #28 on: 08 July 2011, 19:15 »
This or a really soft engine mount and you pulling something.
  • graphic designer.
« Reply #29 on: 10 July 2011, 19:18 »
What hose is it to the brake servo?
