Author Topic: Cutting out when cold  (Read 4827 times)
Offline Shady Pioneer
  • graphic designer.
Re: Cutting out when cold
« Reply #10 on: 05 July 2011, 23:51 »
Changed the temp sensor and no joy, what now? Throttle body was cleaned about 2 months ago.
Offline Len
« Reply #11 on: 06 July 2011, 08:58 »
Have you checked the sensor up on the side of the throttle body?
www.sas.org.uk
www.the-ace.org.uk
  • graphic designer.
« Reply #12 on: 06 July 2011, 09:41 »
No, should I check it or replace it? What sensor is it?
Offline Len
« Reply #13 on: 06 July 2011, 11:06 »
Not sure myself what it is! But it does have a throttle stop on it! So may have some bearing on your problem.
www.sas.org.uk
www.the-ace.org.uk
Offline AudiA8Quattro
« Reply #14 on: 06 July 2011, 11:15 »
Try changing the fuel pump and ecu relays.
  • graphic designer.
« Reply #15 on: 06 July 2011, 12:35 »
What number are these relays? Are get some a stealer. I hate this, once it gets going it's fine, mine you it cut out after getting fuel last night which annoyed me, an S3 almost went into the back of me.
Offline MK3 Menace
  • 98 GTI, big changes are coming...
« Reply #17 on: 06 July 2011, 12:49 »
Mine did this and I replaced Relay 30 and it's been fine since.
Make sure you get a proper one from the stealers, not a lot really of cash really.
Offline Len
« Reply #18 on: 06 July 2011, 12:52 »
I thought Shady knew about the Relays! One of THE most common Mk3 faults! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline trog_nfs
« Reply #19 on: 06 July 2011, 13:23 »
It is quite hilarious that the mk3 moderator is always posting about the most common problems  :grin: :grin:
