Author Topic: 280mm Calipers buggered anyone any suggestions?  (Read 4487 times)
Offline Neo Badness
  • Feet are for pedals
« on: 18 June 2011, 18:48 »
Right, I'm skint. My mk2 is in the garage to get sorted as I've given up trying to get "a good pedal".
They have diagnosed a dodgy caliper which a rebuild kit won't fix :cry:
 Unfortunately the "spare" pair of calipers +hubs I had, I donated to a mate in need and can't very well ask for them back :embarassed:.
I don't wan to fit 256mm calipers as this would mean new discs and general backward step.
So does anybody know of a decent pair of 280mm Girling/ Lucas 54 calipers that I can get? Seems everybody wants arms and legs for them.
The other option, might be a bit mental, is fitting Ate twin pot 2fn42/32 calipers off an R32/TT but I think they take a huge disc 322mm(?) Would I need a bigger master cylinder to use them? Friend is selling them very cheaply though.
I have a friend in a machine shop who may be able to knock up some adapters if this idea is viable? Would be to sit on a G60 hub.
So any help/ suggestions welcome
NB
Offline Mr Blue
Re: 280mm Calipers buggered anyone any suggestions?
« Reply #1 on: 18 June 2011, 19:04 »
get them off someone breaking a mk3 gti? My 280 calipers are off a mk3 :smiley:
Offline Neo Badness
« Reply #2 on: 18 June 2011, 19:09 »
Ah yes, I mean to ask do early mk3 280mmm items fit direct to mk2 hubs?
« Last Edit: 18 June 2011, 19:31 by Neo Badness »
« Reply #3 on: 18 June 2011, 20:55 »
I think from what I have read yes they do.
Offline Neo Badness
« Reply #4 on: 18 June 2011, 21:09 »
Been doing my own research and from what I have read 280mm calipers from a mk3 will bolt right up to a 16v (256mm) hub and the carriers I have should fit too. They also have the added bonus of not commanding the premium that G60 brakes do.  :cool:
R32 twin pots take a 312mm disc and would probably need to run 17's, think for the time being that plan has to be shelved.
« Reply #5 on: 18 June 2011, 21:20 »
312mm setup will fit under 16"s
Offline Neo Badness
« Reply #6 on: 18 June 2011, 21:24 »
I have 16's on it just now.... Kismet? :grin:
Would need my mate to machine up some adapters though. Hmmmmmn....
I'd also prob's need a larger master cylinder to work the bigger pistons?
« Reply #7 on: 18 June 2011, 21:30 »
I would stick with 280mm, you don't really need 312mm on a mk2 unless you have daft power.
Offline Neo Badness
« Reply #8 on: 18 June 2011, 21:43 »
True, but then if I have them I would then need daft power, thus justifying to myself the 16v G60 I've always wanted... You see the logic obviously?
« Reply #9 on: 18 June 2011, 23:37 »
Of course  :grin:
