Author Topic: taking sub out of sub box  (Read 3424 times)
Offline mcgee9t2
« on: 16 June 2011, 09:57 »
Ok I wanted to take my sub out of the box and mount it in the boot to save room.
I remember on here a while ago someone did something simelar. And someone else said that their sub shouldn't be taken out of the box because of some reason and that it would most likely sound crap.
Just wondering is there a general rule as to weather or not your sub can be used with out a box. I.e a certain type of sub or something? Cheers
Offline gm8
Re: taking sub out of sub box
« Reply #1 on: 16 June 2011, 10:24 »
were are you planning on mounting it ? you can get a "freeair" sub , but it would never be as good as a boxed sub. Every sub has its own ideal box dimensions
Offline mcgee9t2
« Reply #2 on: 16 June 2011, 11:15 »
Yeah. What I was going to do was get some wood, make a support and then have a big piece of wood that lays ontop of that. So in effect I have a false floor then cut a hole In that and mount the sub so that the sub is flush with the floor.
Offline B-chi
« Reply #3 on: 18 June 2011, 10:38 »
Different subs suit different enclosures.
Generally a sub designed to play in a box of a particuliar size won't sound very good as a IB (infinite baffle or free air).
Best off to sell your sub and buy one suitable to IB.
Offline vdubman
  • its not a polo-its a mini golf :-)
« Reply #4 on: 03 July 2011, 20:32 »
also if you go for a sealed box they take up less space-less low bass but very punchy
Offline efunc
« Reply #5 on: 17 July 2011, 11:45 »
If you're going to mount it in MDF anyway you could put it in the wheel well in a specially designed enclosure. You could get about 1.25 cu ft of space there and it would sound very good, plus leave you all the boot space.
Offline frenchboy
« Reply #6 on: 26 July 2011, 15:54 »
Or buy one of the subs that go under the front seats so saves you all the room!
Offline _Adam_
« Reply #7 on: 01 August 2011, 14:01 »
or do what Hurdy did (check his mk5 build thread)
Offline Milby
« Reply #8 on: 17 September 2011, 16:20 »
my friend has an escort  :sick: and he took his double sub box apart and mounted them in the floor on a raised boot floor and it really has affected the sound no punch/thud at all now it just sounds like he has good bass from normal speakers :)
MK3 Golf 1.4 SE ;)
Offline joe skandal
« Reply #9 on: 20 September 2011, 21:42 »
You need to be very careful here like mate. The sub box is what gives it its sound. If you are going to take it out of its box its gonna sound crap. If you are gonna mount it in the boot with Nee box you need to be careful and might need to mount some damping material to catch some of the sound, or the bass will just over ride everything, sounding sh!t.
It will look good, but you need to have it angled the right way too, to direct the bass, or again it Will just take over everything.
-Joe
Turn on, tune in, drop out..!
