Author Topic: Fitting a DAB roof aerial  (Read 936 times)
Offline Dan_GTi8v
« on: 15 June 2011, 19:47 »
Tried fitting my DAB radio and aerial today, took it out the box and found the aerial has a seperate wire for the 12v connection. I read something about the mk3 aerial wire having the 12v incorporated into the signal wire, is this right? Can I use one of those seperation plugs to seperate the 12v from the signal wire or should I run the 12v from behind the headunit to the mast?
Everything else is all set up I have normal radio reception just need to get the 12v connected to power the dab feed
Re: Fitting a DAB roof aerial
« Reply #1 on: 15 June 2011, 20:17 »
Run it off the electrical aerial feed or if your standard aerial has an amp use that, red wire from memory.
Offline Seanl
« Reply #2 on: 16 June 2011, 16:05 »
I ran mine from the central locking pump as its nearer. Works a treat!!
