Author Topic: need some help peopleee  (Read 2215 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
« on: 15 June 2011, 12:29 »
right there might be a thread about this but i couldnt find onee    :nerd:
i know its simplee but i dont know how :D
HOW AN EARTH DO I FIT MY SUB AND AMP
hopefully there is a step to step thead out there that someone can link me too :)
thanks guys
Offline dragonfly
Re: need some help peopleee
« Reply #1 on: 15 June 2011, 14:09 »
Google it or look on You Tube - plenty of videos there.  http://www.ehow.com/how_2214812_install-car-amplifier-power-subwoofer.html
Offline Ferdinor
« Reply #2 on: 15 June 2011, 21:33 »
Firslty place the sub and amp in a postion where you like them, once you have found it mount them down so they wont go anywhere, now assuming your battery is in the engine bay run cable from the battery down the left or right side of your car and within 18inches of the battery make sure you have a inline fuse and also make sure you are running at least 4gawg cable, now when in the boot the live cable needs to go onto the connecter on the amp under live or positive or whatever, now thats done run a cable from ground/negative conector on the amp, this need to be as short as possible and run to a solid piece of metal/frame (i would advise finding a pre drilled hole and mounting it with a nut and bolt) once the hole is found make sure you rub the paint work down to metal not paint so it has better contact. now thats done you need 2 cables going to your head unit (these must be run down the other side or middle of the car do not run them with the live cable) one will be an rca connector, now plug that into the input plug on the amp and the subwoofer output plug at the back of your head unit or if it only has one output put it in there, now the second cable is usally blue it will be blue on your  headunit, its just a signal cable telling your amp that the headunit is switched on, it doesnt need to be thick cable as its only sending a signal. now last job is to run the + & - to your sub box pretty simple go to either of the channels on your amp if you have a bridgable amp but + in one channle and - in the other, now your all done you can power up, just make sure you have a quick read over how to tune the amp so it doesnt blow your sub, nothing difficult  :smiley:
Hope this makes sense and helps
Offline tobybrennan
« Reply #3 on: 16 June 2011, 11:14 »
thank you so much
