Author Topic: Trim Removal  (Read 1467 times)
Offline Nebbo
Trim Removal
« on: 05 April 2005, 20:34 »
How do i go about removing the GTI trim from my MK2 golf? and do i need some sort of adhesive to stick it bak on well? Wanna remove it to check rust out
Ben
Veedubgt18v
Re: Trim Removal
« Reply #1 on: 05 April 2005, 20:38 »
the arches are held on by rivets that need drilling out and the side strips are clip on if its a late model or stuck on if its really early
Offline Nebbo
Re: Trim Removal
« Reply #2 on: 05 April 2005, 20:41 »
when u say side strips - u talkin bout the part that is runnin down the side of the car along the sill? Sorry im a noob  :tongue:
Veedubgt18v
Re: Trim Removal
« Reply #3 on: 05 April 2005, 20:42 »
the sill is on the bottom of the car nearest the ground it is held on with a few screws and clips the side strips are the bits halfway up the doors! :smiley:
Offline ...joe
Re: Trim Removal
« Reply #4 on: 05 April 2005, 21:10 »
the side skirt/sill things are also stuck on and are very easy to break!!! do it carefully!
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Nebbo
Re: Trim Removal
« Reply #5 on: 05 April 2005, 21:19 »
if they are also stuck on - wot is the best thing to use to restick them on? and also are they riveted on?
Offline ...joe
Re: Trim Removal
« Reply #6 on: 05 April 2005, 21:27 »
either get new ones or use something like sikoflex adhesive or some hardcore double sided tape. clean up the area very well before hand though.
Offline The Hoax
Re: Trim Removal
« Reply #7 on: 06 April 2005, 01:01 »
I've been checking threads and it seems like loads of us are thinking about dealnig with rust under the body kit during the spring. Matybe we should compare notes about what sh!te we find and  the best solution to  creating a lasting solution to the problems we find eg repair panels, waxoyl, sell the f*ck*r etc.
