Author Topic: Axle bushes  (Read 1311 times)
Offline Screech16v
  • MK3 20vt AGU
Axle bushes
« on: 12 June 2011, 15:25 »
hi guys,going to be fitting new rear axle bushes soon,mot is due :sad:,now i have bought some febi oe ones but also i have some of them poly bush insert jobbies too ,now i know some of you say standard is best and others like to go for the full poly type so maybe a combination of the two would be best not to flexible or to stiff,anyone got any expierience of these :smiley:
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Axle bushes
« Reply #1 on: 12 June 2011, 18:36 »
How exactly were you planning on utilising both types of bushes on the rear beam?   :huh:
Re: Axle bushes
« Reply #2 on: 12 June 2011, 19:38 »
You can get poly inserts that fit into the standard bush, I would not bother.
Offline Screech16v
  • MK3 20vt AGU
Re: Axle bushes
« Reply #3 on: 12 June 2011, 19:49 »
So best just sticking with the standard then,got the inserts for 99p on ebay auction where as ive seen them for a tenner before so havent really lost ought.
Offline vdubnut
Re: Axle bushes
« Reply #4 on: 12 June 2011, 22:00 »
recently had polys fitted and handling ace ! old ones were totally shot though! lol
Re: Axle bushes
« Reply #5 on: 12 June 2011, 22:00 »
Yeah I'm aware of this type but going on what Screech has posted it would mean destroying a brand new set of standard bushes just to insert the poly ones as well. Pointless. If you're fitting poly inserts then you may as well just push them into the existing bush shells.
Offline Screech16v
  • MK3 20vt AGU
Re: Axle bushes
« Reply #6 on: 12 June 2011, 22:45 »
Sorry for the confusion theses are what i meant,they just simpley push in to the new bush
Re: Axle bushes
« Reply #7 on: 12 June 2011, 22:51 »
I've not seen that type before, only the poly ones that replace the entire rubber guts of the standard bushes retaining the outer metal casing.
Do theses ones even do anything and I also imagine these wouldn't even stay in place on older worn standard bushes.
Offline Screech16v
  • MK3 20vt AGU
Re: Axle bushes
« Reply #8 on: 12 June 2011, 22:55 »
Yeah they are well tight to get in they come with some lube,make the standard bush a bit more firm,i would never fit these to an old worn bush though :smiley:
Offline Khare
  • The bear that khares
Re: Axle bushes
« Reply #9 on: 13 June 2011, 12:16 »
You might as well fit the if you've got them and seeing as they don't really complicate the job much  :smiley:
