Author Topic: Mk2 8v tappets noisy  (Read 7540 times)
Offline TreadGingerly
Re: Mk2 8v tappets noisy
« Reply #10 on: 13 June 2011, 14:18 »
I had to flush mine twice. It worked, 145k on the clock.
Offline AudiA8Quattro
« Reply #11 on: 13 June 2011, 21:10 »
As already said, check oil pressure.
Offline Benrevs
« Reply #12 on: 13 June 2011, 21:31 »
Could be a noisy injector or two. Put a screwdriver to your ear and the other end on each injector.
Offline Bigdunc
« Reply #13 on: 14 June 2011, 09:17 »
What engine flush is everyone using? Are u using the adative u add to oil or the 5l flush u drain oil and put flush in and run engine for 10 mins??
I'm getting my oil pressure checked in few days when mate bk from holiday
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #14 on: 14 June 2011, 13:24 »
Yeh the injectors on these are pretty loud after a good few miles. Deffo worth checking too. Mine are too loud, might get some new ones.
« Reply #15 on: 14 June 2011, 20:28 »
I would avoid engine flush. :smiley:
Never been keen on it
Offline mk2bal
« Reply #16 on: 14 June 2011, 23:08 »
Yeah don't put de-greasers in where your meant to put lubricants...
Offline Sam
  • Sam I am
« Reply #17 on: 14 June 2011, 23:50 »
My top end sounds like a derv but not planning on flushing
Offline Bigdunc
« Reply #18 on: 15 June 2011, 09:08 »
Is there a way of testing my tappets with rocket cover off and cam still in place? Will the noisy one not have as much play as the others??
Will do the injector test tonight after work if weather nice :)
« Reply #19 on: 15 June 2011, 09:32 »
No real way of telling tbh.  :smiley:
