Author Topic: Mk2 8v tappets noisy  (Read 7536 times)
Offline Bigdunc
« on: 11 June 2011, 11:23 »
I have a mk2 8v gti pb engine, it's don't 140k
Just recently the top end has started to get noisy ticking quite loud.
I had the tappers changed about 6k ago,
Car never had head off that I can see in the paperwork,
Is there a way of making engine quiet again?
Car has had regular oil changes aswell
Thanks
Offline mwep201081
Re: Mk2 8v tappets noisy
« Reply #1 on: 11 June 2011, 12:32 »
try using an engine flush at the next oil change....
Offline Bigdunc
« Reply #2 on: 11 June 2011, 13:30 »
i used engine flush adative on last oil change :(
its not all the tappets i dont think it sounds like just 1 or 2, ive added hydrolic tappet adative to try quiet them down but not seamed to have worked.
 :angry:
Offline mwep201081
« Reply #3 on: 11 June 2011, 14:08 »
One of the galleries must be quite blocked then, or the new tappets were defective?
Offline Steve_B
« Reply #4 on: 11 June 2011, 14:35 »
Could be a blocked oil pump? Have you looked at the oil pressure?
Offline southcoast_gti
« Reply #5 on: 11 June 2011, 15:53 »
oil pick up pipe might be slightly blocked? take the sump off and inspect everything, mines doing the same thing but on and off so im thinking it a pump/pickup pipe issue
Offline Bigdunc
« Reply #6 on: 11 June 2011, 17:04 »
Pump was one of my thoughts,
Years ago I had a noisy mk2 16v and the garage used a full engine flush solution where u drain the oil and leve filter in then fill up engine with a 5l of flushing oil and leave running for 15-30 mins then drain and do oil change like normal, that worked well for that car but u can't seam to buy it anymore only the flush adatives.
Might be worth doing oil pump change anyway to be safe
« Reply #7 on: 12 June 2011, 00:12 »
I would drop the sump and check the oil pick up pipe.
Offline Bigdunc
« Reply #8 on: 12 June 2011, 13:32 »
will get in on ramps next weekend when i can get access to some as dont fancy taking sump off on the drive, for the price of a new oil pump and having to take the sump off anyway its prob worth putting in a new pump while sump is off anyway im guessing
« Reply #9 on: 12 June 2011, 14:55 »
Yes well worth doing :afro:
