Author Topic: Inlet manifold/rocker cover questions  (Read 1073 times)
Offline packardjc
« on: 10 June 2011, 13:40 »
Ok so I want to give them both a good clean and lick of paint.
1. Do I need to be replacing the gaskets? Just got new rocker gasket last week fitted.
2. What kind of prep do they need before painting other than a good clean? (got some gunk)
3. I take it some bog standard heat-resistent paint will do?
Re: Inlet manifold/rocker cover questions
« Reply #1 on: 10 June 2011, 13:42 »
1) yes new gaskets needed
2) good clean as required.
3) Hammerite will be fine
Offline packardjc
« Reply #2 on: 10 June 2011, 13:55 »
So they don't need sanding or owt? Take it I can get gaskets from GSF?
Offline packardjc
« Reply #3 on: 10 June 2011, 14:03 »
GSF are giving 2 rocker sets for the ABF engine, confusing...
Offline Len
« Reply #4 on: 10 June 2011, 14:04 »
I always find GSF confusing! ECP is much better!
www.sas.org.uk
www.the-ace.org.uk
Offline Seanl
« Reply #5 on: 10 June 2011, 16:47 »
Get the gasket from vw. GSF ones, or any after market gaskets tend to leak a little. If you wanna do it properly, take you breather pipe off too. You will need to replace the seal on the inside as well though. Part numbers are 051 103 483A -Gasket, and 028 103 500 - Seal. Prices are £16.80 for gasket, and £3.00 for the seal. Hope this helps.  :wink:
Offline Bellend
« Reply #6 on: 10 June 2011, 17:43 »
Go to VW for your gaskets.
Any other "OEM quality" bollox gaskets are total crap.
Where all my moneys went.
