Author Topic: How easy to remove manifold on turbo  (Read 641 times)
Offline balderz
« on: 09 June 2011, 18:44 »
well my car is still sounding like a tractor after changing manifold on the cat so must be gasket on the mainfold or its cracked (how easy is it crack ?)
so my question is how easy is it to remove the manifold and check
Offline RTechUK
  • R-TECH OFFICE 01455 617233
Re: How easy to remove manifold on turbo
« Reply #1 on: 09 June 2011, 19:20 »
. Drop down pipe 4 17mm nuts, lower turbo mount 6mm allen bolts, remove lower part of tip 5mm Allen bolt,  remove top boost pipes from turbo, undo 17mm nut manifold to turbo, the turbo will drop down about 2" which will give you enough room to get to the lower 12mm manifold nuts.
 01455 617233
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 10 June 2011, 00:32 »
i would budget atleast half a day depending how handy with the spanners
