Author Topic: Help water in my boot arrgghh  (Read 1384 times)
Offline brett
« on: 07 June 2011, 17:05 »
afternoon all just wondering if anyone had any ideas ,gone to get tool underneath carpet in the boot where the spare tyre is and the carpet was soaked in the corner :sad:,any help appreciated,have change the rear light already as one of the fixings was broken and the seal seemed okay,cheers brett
Offline tweed
Re: Help water in my boot arrgghh
« Reply #1 on: 07 June 2011, 17:20 »
roof aerial?
Offline chiefwhosm
« Reply #2 on: 07 June 2011, 17:57 »
Try pushing on the rear light(s) with your body weight and one hand, while tightening up the screws with your other, pushing your weight over each screws area in turn. I found mine had managed to untighten because I hadn't screwed them up enough while cleaning moss out from behind my rear lights, so seal was fine, but a rather large gap :)
Offline brett
« Reply #3 on: 07 June 2011, 18:21 »
cheers chaps will have  a look at both of them options
Offline Egg On Toast
« Reply #4 on: 07 June 2011, 18:24 »
is it a sunroof model? some older cars channel leaks to the rear of the car. check the roof lining for signs of dampness.
Offline brett
« Reply #5 on: 07 June 2011, 18:26 »
yeah it does have a sunroof will also have a look at that  ,that one could be the money shot lol,cheers for all your help chaps
Offline dom
  • Back in a Mk4
« Reply #6 on: 07 June 2011, 18:57 »
My money is on rear light seals :wink:
Offline brett
« Reply #7 on: 07 June 2011, 19:00 »
oh well guess what i'll be doin tomoro lol,after i been to vw and collected my tensioner bolt for power steering belt as mines feckin rounded and the belts squeekin like a biatch grrrrrr
« Reply #8 on: 07 June 2011, 21:57 »
Pickup a pair of new seals from VW they are not expensive also do not overtighten the bolts as you will crack the light.
Offline harlemex
« Reply #9 on: 08 June 2011, 20:20 »
yeah be careful with the tightening as you can snap the studs too. I have had the same problem. the foam seal seems to act like a sponge and soak in the water and then release it into the boot.
