Golf mk3
hardmonkeys
Braking
Topic: Braking (Read 999 times)
sychosis
Here all the time
Braking
07 June 2011, 08:42 »
Hi quick question, would the pads on the rear wearing thin have an affect on the abs kicking in at low speeds?
justalex81
Re: Braking
07 June 2011, 09:11 »
i think thats a faulty abs pump but not sure. does the abs light come on at all?
For all Domestic and Commercial gas,heating and hot water needs.
sychosis
Here all the time
Re: Braking
07 June 2011, 09:35 »
No no abs light
Wayne
Sir Postalot
Re: Braking
07 June 2011, 10:05 »
Pads will make little or no difference.
Get it scanned for fault codes however if you have no light someone may have removed the bulb.
sychosis
Here all the time
Re: Braking
07 June 2011, 10:58 »
Ok cheers, will check bulb later
Getting it booked it for full service and timing belt change at end of month, as off for a couple of weeks, will get them to have a look at codes for me.
sychosis
Here all the time
Re: Braking
07 June 2011, 13:49 »
Just found someones moved the bulb so it doesn't show through.
sychosis
Here all the time
Re: Braking
Reply #6 on:
07 June 2011, 16:21 »
What would happen if I took out the relay for a bit?
benvictors
bgk Tuning - coming soon!!!
Re: Braking
Reply #7 on:
07 June 2011, 22:54 »
Check the wires on the two front abs sensors, mine was doing this for a while with intermittent abs light, then stopped but constant abs light. Turns out my wires were resting on my driveshaft and gradually wore through.
Could be worth checking
sychosis
Here all the time
Re: Braking
Reply #8 on:
08 June 2011, 14:31 »
Ta, won't be driving it for a bit now, going to be out country for two weeks
and got it booked in for full service day after i come back
sharki786
GOT BOOST??
Re: Braking
Reply #9 on:
08 June 2011, 15:02 »
when your back, give me a pm and i could check it out for you.
*****MK3 Anniversary*****
*****MK4 GTI T*****
Golf mk3
hardmonkeys
Braking
