Author Topic: Driver side window problem  (Read 671 times)
Offline will_jb
« on: 04 June 2011, 20:07 »
The driver side window is stuck half way down therefore me not being able to use the car.
Have tried alsorts to get the electronics to move the window back up but nothing is working.
Any ideas and is this a common problem?
CHeers
Offline swede28
  • <a href="http://www.mybannermaker.com" target="_bl
Re: Driver side window problem
« Reply #1 on: 05 June 2011, 20:21 »
my car did the same all i did was try locking the windows with the key it worked for mine it went straight up  :grin:
Offline Seanl
« Reply #2 on: 05 June 2011, 20:49 »
Take the door card off, undo the clamps for the window, and prop it up with a bit of wood. That will at least make it ok for the short term. After that, check voltage at the switch, the plug at the bottom of the mechanism, then at the motor. Very common problem, usually there is a problem with the mechanism. Can pick them up relatively cheaply on fleabay.  :smiley:
