Author Topic: Temp sender to blame for leak!  (Read 2023 times)
Offline the_stink
  • A3 140 TDI
« on: 04 June 2011, 16:43 »
So after cleaning all the crap off the top of the oil cooler started the car and the leak wasn't from the gasket but from the rear temp sender at the back oil just started to trickle down the back!
So im assuming its the o ring has perished im really annoyed as i could of bloody got the part this morning but that said i have got an adjustable spanner so cant even remove the temp senders to check the o rings etc
Will have to wait till my brother gets home with his tools!
Re: Temp sender to blame for leak!
« Reply #1 on: 04 June 2011, 23:29 »
From memory yes they have a small o ring fitted.
Offline the_stink
  • A3 140 TDI
« Reply #2 on: 05 June 2011, 08:18 »
In the end my mate chris up the road had a spare one
But the oil light is still flashing? The one i removed which was closest to the engine was black, now not sure if this was due to it being broken and oil coming through it but the one i replaced it with was white like the on at the front
Offline JC
  • Back in the North.
« Reply #3 on: 05 June 2011, 08:31 »
i am sure they are different for a reason,
and going off
http://www.gsfcarparts.com/community/index.php?topic=2506.0
that is cos one is high pressure, one is low thus the warning going off.
need another black/brown one.
Offline the_stink
  • A3 140 TDI
« Reply #4 on: 05 June 2011, 12:22 »
and going off
Ahh ok right is that going to make much difference if i drive it for a coupel of days till i can get a replacement? ill be calling vw tomorrow see fi they got any in stock
Offline mk2bal
« Reply #5 on: 05 June 2011, 14:16 »
It won't do any harm purely using it as a plug, but you won't have the warning from it you should have should you develop a fault
Offline the_stink
  • A3 140 TDI
« Reply #6 on: 05 June 2011, 14:54 »
yeah plug action it is! hopefully i can get a new one tomorrow!!  :smiley:
Offline Cory
« Reply #7 on: 08 June 2011, 13:05 »
i have a spare plug in the tool box donated by the RAC man after my original fell apart whilst driving  :smiley:
