Author Topic: Boost guage fitting on a PD130  (Read 1987 times)
Offline tsr_adi
« on: 03 June 2011, 08:40 »
I might be fitting a boost guage onto a mates Ibiza PD130, And I know it has to be T'eed into a vac pipe, but I've never worked on one, so where does it need tapping into? I assume they have a vac pipe to the ECU?
Offline Damon1991
Re: Boost guage fitting on a PD130
« Reply #1 on: 05 June 2011, 00:23 »
No.. Firstly the ECU is only electrical and does not create vacuum at all, is merely electrics.. Secondly fitting a boost gauge on a diesel is different to fitting one on a petrol, on a petrol as you did say correctly you connect it to a Vacuum line but on a diesel you have to connect it to a boost pipe.. I believe you can buy a threaded T-piece and tap into a boost pipe.. this will do the trick.. Hope this helps
Thanks Damon
Offline Adam
« Reply #2 on: 08 June 2011, 02:56 »
As per Damon.
Tell your mate to buy this EGR Valve from Allard, they have a take off to fit a boost gauge.
What year is the Ibiza?
Down Hill From Here.
