Author Topic: Oil leak  (Read 2599 times)
Offline nightroamer
  • Mk3 16v
Oil leak
« on: 02 June 2011, 11:46 »
Hi guys, I've suddenly got an oil leak on my abf.
I can see from underneath it's dripping off the filter housing, but from above the filter.
Had a good look and the filter isn't leaking, all sealed nicely.
Looks like it maybe from one of the joints in the housing.
Is this common? Any ideas where I should be looking?
Thanks
Offline Agreeable Slick
  • Unit
Re: Oil leak
« Reply #1 on: 02 June 2011, 11:50 »
If it's from the oil cooler housing then it is likely that the pressure sender on it has popped a seal.
Easy fix and a couple of quid from an auto factors.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #2 on: 02 June 2011, 11:54 »
Is that on the top of the housing?
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #3 on: 02 June 2011, 12:04 »
Just had a quick look and the three sensors on the top are not leaking, looks like onee of the metal-metal joints on the oil cooler housing.
Are there gasketed? How does it come apart?
  • Unit
Re: Oil leak
« Reply #4 on: 02 June 2011, 12:08 »
Easy way to check if they are is to start the engine up, then get a mate to give it a bit of gas whilst you watch the top of the cooler housing. They will only leak when the system is pressurised.
P.S. make sure you have a good level of oil in the sump before you do.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #5 on: 02 June 2011, 12:19 »
Nice one, defiantly not leaking From the top.
Pretty sure its a joint leak.
Can't find the cooler in the Haynes manual, anyone got any info?
Offline AudiA8Quattro
Re: Oil leak
« Reply #6 on: 02 June 2011, 13:31 »
There is a gasket on the back of the cooler.
Also see if its mounted securely, i have seen one on an Audi where the nut had come loose.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #7 on: 02 June 2011, 15:42 »
Ok cool, think it seems to be coming out the back of the housing somewhere.
Anyone got any pics
Offline Gash
Re: Oil leak
« Reply #8 on: 02 June 2011, 17:34 »
change the oil cooler.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #9 on: 02 June 2011, 19:30 »
Ok cool,
Anyone know a good supplier?
Euro do hella ones and eBay do febi bilstien items?
Are these ok?
