Author Topic: Oil leak  (Read 2601 times)
Offline Gash
Re: Oil leak
« Reply #10 on: 02 June 2011, 19:36 »
Got my from gsf be much better than the other two places you mentioned
Offline AudiA8Quattro
Re: Oil leak
« Reply #11 on: 02 June 2011, 21:43 »
You might just need a new seal.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #12 on: 02 June 2011, 21:47 »
Ok, worth a try.
Does anyone have a guide on removing this? Not mentioned in Haynes
Re: Oil leak
« Reply #13 on: 02 June 2011, 22:42 »
Remove oil filter, disconnect water hoses, remove the nut, remove oil cooler.
Its pretty simple.
The gasket is just an o-ring seal, it will cost a couple of quid at most.
Offline nightroamer
  • Mk3 16v
Re: Oil leak
« Reply #14 on: 03 June 2011, 00:07 »
Its pretty simple.
Thanks mate, will give it a pop tomorrow.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: Oil leak
« Reply #15 on: 04 June 2011, 10:48 »
Hella and Febi Bilstein are both decent brands, I'd go with the cheapest one.
Offline tactical_spartan
Re: Oil leak
« Reply #16 on: 04 June 2011, 13:23 »
Hi guys, I've suddenly got an oil leak on my abf.
I can see from underneath it's dripping off the filter housing, but from above the filter.
Had a good look and the filter isn't leaking, all sealed nicely.
Looks like it maybe from one of the joints in the housing.
Is this common? Any ideas where I should be looking?
Thanks
Hi, I had the same problem on my 16v with the ABF it has a known fault of shaking the oil filter loose so check that and re tighten. :wink:
BIRCHY
1994 VW Golf GTi 16v
