Author Topic: 8V engine life  (Read 3994 times)
Gavv8
8V engine life
« on: 01 June 2011, 19:43 »
How long can you expect a standard 8V engine to last with normal servicing before it need parts replacing and what is the best advice regarding servicing?
Offline snifferdog
Re: 8V engine life
« Reply #1 on: 01 June 2011, 19:47 »
They are pretty bullet proof if looked after. There has been plenty on here in the past with over 200k mileage  :shocked: My old one had 138k on the clock but drove perfectly and used no oil or water.
With regards to servicing, I think the best advice would be to do it as often as possible and to use the highest quality brands that you can afford.
Gavv8
Re: 8V engine life
« Reply #2 on: 01 June 2011, 19:51 »
Are the normal service intervals ok or should i service more often as the mileage racks up, mine is on about 126000 and has a full history, uses no fluids and drives very well.
Christo77
Re: 8V engine life
« Reply #3 on: 01 June 2011, 19:59 »
Just as snifferdog says..
Mine is on 106k, the engine is crisp and healthy as the day it was new i imagine but since i've owned it gets regular quality oil/filter changes, about every 3k i do mine even if some might think over the top..but i enjoy it ;)
Offline snifferdog
Re: 8V engine life
« Reply #4 on: 01 June 2011, 20:02 »
My mk4 is on 145k and is totally mint. I think the normal service intervals should be ok, but if youre servicing it yourself and have some spare cash one month then it cant help to treat it  :laugh:
Re: 8V engine life
« Reply #5 on: 01 June 2011, 20:46 »
Should / will go on for a long time if looked after.
Offline gti gaz
Re: 8V engine life
« Reply #6 on: 01 June 2011, 22:11 »
mine is on almost 160k and does not miss a beat i change my oil every 6000 miles will very goo oil and do plugs and bits about every 10k   15k     a mate has got 205k on his and still keeps up with mine
 Any one in cornwall lets sort more meets!!!!
Offline dom
  • Back in a Mk4
Re: 8V engine life
« Reply #7 on: 01 June 2011, 23:08 »
I also do an oil change every 6k miles and check everything else regularly. Mine has only just turned over 98k so isn't even worn in yet :smiley:
Offline Khare
  • The bear that khares
Re: 8V engine life
« Reply #8 on: 01 June 2011, 23:13 »
Oil change + filter every 5000 miles for me and plugs and air filter cleaning every 10k for me. Engine is on 115k and runs sweet as a nut.
Offline georgiebaby
Re: 8V engine life
« Reply #9 on: 01 June 2011, 23:39 »
dont know if its the same engine but got a 2ltr 8v in my audi coupe and thats on 197.000 and never misses a beat.
