Author Topic: 8V engine life  (Read 3998 times)
Re: 8V engine life
« Reply #10 on: 01 June 2011, 23:44 »
I also do an oil change every 6k miles and check everything else regularly. Mine has only just turned over 98k so isn't even worn in yet :smiley:
Nice miles for the year, will be a milestone when you hit 100k then.  :smiley:
Offline tdi_blu
  • Golf Gti & T4 2.5 tdi
Re: 8V engine life
« Reply #11 on: 02 June 2011, 07:53 »
I also do my oil and filter about every 5k to 7k and mines now on 110k and drives sweet as a nut never had any problems with it.I still think the 8v lump is the most reliable out the lot.
Golf Gti
Offline benvictors
  • bgk Tuning - coming soon!!!
Re: 8V engine life
« Reply #12 on: 02 June 2011, 08:06 »
Mines an early 96 and has VW service history up to 2004, then independant til 2006, then i dont think it was serviced til i got my hands on it at the end of 2009.
Has a minor oil leak on the sump gasket and has had a replacement gearbox but has never let me down and fires up first time evrytime  :cool:
Not bad for just over 200,000 miles, thats approximately around the world 8 times  :shocked:
I service once a year also, which is about 5-6000 miles for me
Offline Sii
Re: 8V engine life
« Reply #13 on: 02 June 2011, 08:46 »
Easily 250K just on regular servicing!  :grin:
Offline dom
  • Back in a Mk4
Re: 8V engine life
« Reply #14 on: 02 June 2011, 10:48 »
Yup! It only had 78k on the clock when I bought it last Feb  :smiley:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: 8V engine life
« Reply #15 on: 02 June 2011, 17:19 »
I have recently had to do a full engine overhaull on an 8v 2E engine from a passat
It was a taxi, then used for a 80 mile daily commute for years 259k miles.  The car its self was very clean for the miles.
Reason for overhall was....
*Carry out full service & MOT investigate numerous faults as listed.   <this is what customer complained about
Investigate rattle/tapping from engine when cold
oil leaking
This is what we found on the service.
Oil leak from camshaft area
Oil leak from crank seal
Oil leak from head gasket area
Engine knocking when cold adv possible piston slap
Oil pressure warning light on when revs drop below 800rpm
Noise from hydraulic lifters - Possible oil pressure
Coolant leak from radiator
Coolant leak from cylinder head flange
O/S/R Tail light bulb out
Had been serviced every year (turned out to be every 15-20k miles)  And not been serviced for the past 4 years (40k miles  :undecided: :undecided:)
Anyway old boy told us to do the lot, so it had new piston rings, bottom end bearings, oil pump, water pump, cambelt, new intermediate shaft seals and bearings, head gasket, tappets,  valve seals.. the whole lot.
Madness!  Waste of money if you ask me but its nice to see it done, that engine will do another 200K miles + now.
To be honnest it didnt need a rebuild,  the piston slap would have gone on forever, wasnt even smoking.  Just had a small oil leak from the cylinder head.  there was so much gunk in the engine from lack of oil changes though, it has lost oil pressure.
Wear on the bottom end was small, very little end float on the crank, within spec.
And this one wasnt well serviced.  So of you keep up the oil changes and look after it... i reccon it will do a whole lot more miles.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Gavv8
Re: 8V engine life
« Reply #16 on: 02 June 2011, 18:18 »
Good thats what i wanted to hear, more money to spend on petrol :grin: :grin:
Offline stainesy
Re: 8V engine life
« Reply #17 on: 03 June 2011, 11:47 »
Mine has done 126k and is great. Am changing my oil next weekend what oil should I use and what grade?
Also how much many litres do I need?
Offline tweed
Re: 8V engine life
« Reply #18 on: 03 June 2011, 12:20 »
Mines about to hit 30,000  :grin: So Mines got plenty of life left in it. Done about 4000 miles in a year and I'm yet to finish the vr6 to drive daily and stick the 8v in the garage and not drive it lol
Offline robz
Re: 8V engine life
« Reply #19 on: 03 June 2011, 16:58 »
hahaha hilarious, mines on circa 83000 iirc, and its fecked!
having to replace the stem seals cos it smokes like bastard :D
