Author Topic: fuel gauge  (Read 1176 times)
Offline stainesy
fuel gauge
« on: 01 June 2011, 11:05 »
My fuel gauge has started to do my head in. If I have over 1/4 of a tank its ok but bellow that and it seems to get stuck in the red then it takes ages wile driving for it toslowly creep up to the level it actuly is. It also sticks at 1/4 of a tank so I think iv got plenty and then it sudenly drops into the red.
Any ideas what's going on?
Re: fuel gauge
« Reply #1 on: 01 June 2011, 11:17 »
Could be a faulty sender but they are not the greatest idea.
Pull the lead off and earth it and see if the gauge goes up if it does then you have a sender problem.
Offline stainesy
Re: fuel gauge
« Reply #2 on: 01 June 2011, 13:35 »
Where is the sender on the fuel tank?
Easy to change?
Re: fuel gauge
« Reply #3 on: 01 June 2011, 14:09 »
Easy to change?
Look in the boot towards the rear seat, you will see the cover etc.
Offline gti gaz
Re: fuel gauge
« Reply #4 on: 01 June 2011, 15:39 »
i have same problem think its the sender easy enough to change or take out and clean up let me know how you get on if its not your sender
 Any one in cornwall lets sort more meets!!!!
Offline dom
  • Back in a Mk4
Re: fuel gauge
« Reply #5 on: 01 June 2011, 23:18 »
They can be a right b!tch to change sometimes, someone posted a guide on here a few weeks ago....i'm sure if you try a search it will appear :wink:
Re: fuel gauge
« Reply #6 on: 01 June 2011, 23:47 »
Len has done a guide if it helps.  :smiley:
