Author Topic: AGG to 2E conversion  (Read 2600 times)
billabong
« on: 30 May 2011, 18:01 »
Hi Guys,
I'm soon going to be doing a conversion from my AGG to nice and shiny 2E. Ive got the ECU, loom and engine (with all ancillaries).
I'm changing the box at the same time (to one that doesnt crunch in reverse!)
How much of the loom will need changing? Will it need changing all the way to the fusebox? Will I need to change the ECU or will my current one work? (I imagine not as the sensors are different?)
Will I need to recode my key to the new ECU or does the 2E not have an immobiliser?
Its the first engine change i've done, the most I have done before is gearboxes, I know this is a big jump but myself and my mate that is helping are quite technical and mechincally minded so hopefully should be able to manage.
Can anyone foresee any potential problems we might encounter?
Many Thanks
Will
Offline F17BAD
  • Golf MTM S3 GTI TURBO
Re: AGG to 2E conversion
« Reply #1 on: 30 May 2011, 18:41 »
look after my old engine.. it was always good to me  :sad: :cool:
their was no coded sh!t on the early ones so you are all good to go their
Not no ordinary GTI....
www.mixcloud.com/kells/
billabong
« Reply #2 on: 30 May 2011, 19:14 »
haha, just got your PM about immo so thats cool :)
The only bit i'm scared about is the wiring :P The rest is just lift in and bolt in :P
I will look after her! :)
« Reply #3 on: 30 May 2011, 20:33 »
Would be better to switch back to the 2e ecu and loom set up if you have it.
Offline Khare
  • The bear that khares
« Reply #4 on: 30 May 2011, 20:37 »
Infact you need to switch to the 2E ECU. It has an ISV and various other bits and that AGG doesn't, and vice versa (crank sensor).
« Reply #5 on: 30 May 2011, 20:39 »
That is what I was thinking, I remember a thread of yours saying they were a lot different.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 30 May 2011, 20:52 »
AGG and 2E are diffrent injection systems all together the 2E was digifant  and the AGG was Simos.   ECU is a must, engine loom for sure, dashloom, that can stay.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
billabong
« Reply #7 on: 30 May 2011, 21:14 »
I'm glad the dashloom can stay, that would mean it taking even longer!
The clocks are same?
Ive got the ECU and engine loom so that will help :)
Will
« Reply #8 on: 30 May 2011, 21:18 »
Can I ask the reason for wanting to switch back to the older engine :smiley:
Offline F17BAD
« Reply #9 on: 30 May 2011, 21:19 »
Yeap i give him my ECU and the loom with the engine, i have the origial clocks that was in the car when i bought it, ill sell them if need be but yours will work fine  :smiley:
Wayne, its my old lump - clean good strong engine and the 2E's were the best of the 8v bunch (my opinion).
