Author Topic: using a lot of oil...  (Read 1887 times)
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« on: 30 May 2011, 14:54 »
have had the oil pressure checked and it's absolutely spot on, but in the space of a few hundred miles of driving (admittedly i was giving it some) the oil has gone from the max on the dipstick to just below the min...
this seems like a hell of a lot of oil used... any ideas? cheers
Offline gibby
Re: using a lot of oil...
« Reply #1 on: 30 May 2011, 15:09 »
Sorry to state the obvious, but oil leak ?   :huh:
I think you need to give us a bit more info.
......now officially dubless.
Offline andynorfolk
« Reply #2 on: 30 May 2011, 15:12 »
i haven't noticed any oil leaking though :S
and the oil pressure being fine makes it seem a bit strange...
if there is a leak where is it most likely to leak from?
Offline gibby
« Reply #3 on: 30 May 2011, 15:16 »
If you lost that much (think it will be approx 0.75L between marks) you should be able to see a leak. Daft question, when you checked the levels did you push the dipstick far enough back in ? Also, is there blue smoke coming out of the exhaust ? That would suggest burning some oil.
Offline mk2mark..
« Reply #4 on: 30 May 2011, 16:56 »
valve stem oil seals gone ? burning oil blue smoke coming from the rear ?
Offline andynorfolk
« Reply #5 on: 30 May 2011, 18:41 »
i definately put the dipstick in deep enough aha
and there hasn't been any blue smoke from the exhaust...
i've parked it over a piece of cardboard so i can see if it's dripping and where it's dripping from
Offline gibby
« Reply #6 on: 30 May 2011, 19:26 »
You're either wrong and messed up your checks or you've got an oil leak. It can't be anything else.
« Reply #7 on: 30 May 2011, 20:01 »
If you have not got a leak then it must be burning it.
Offline danny_p
« Reply #8 on: 30 May 2011, 20:11 »
allways worth checking that the oil's not finding it's way into the water. no uncommon for the oil cooler to fail and it to pump the coolant full of oil
all the VW's have gone bar 1.
Offline mr mk2
« Reply #9 on: 30 May 2011, 21:04 »
When checking ur oil did u leave it some time after 'giving it some' b4 re-checking as if u read it straight away u could get a faulse reading
