Author Topic: using a lot of oil...  (Read 1888 times)
Offline Sam
  • Sam I am
Re: using a lot of oil...
« Reply #10 on: 30 May 2011, 21:37 »
You checked the back of your car, the mk2 has some mad as air flow on the rear (hence why it gets mega dirty on the arse end quick) and may be lathered in oil on the rear. Just a thought  :smiley:
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
« Reply #11 on: 30 May 2011, 23:23 »
if the oil cooler has failed would that also cause the oil light to flash on the dash...? as this is permanently flashing but the oil pressure is spot on and both switches have been replaced
