Author Topic: Check brake pads warning light  (Read 1043 times)
Offline bullzeye
« on: 29 May 2011, 11:47 »
i have just put some mud flaps on my car, but had to take each wheel off to be able to screw the flaps on, since putting the wheels back on , "check brake pads"  light keeps poppin up any ideas what will be causin this?
by the way, imanaged to get  a original set of mud flaps with white logos on the rear ones, for £20 on ebay, happy days!!
« Last Edit: 29 May 2011, 13:13 by bullzeye »
cheapest mobile provider arround order a free sim with £5 credit www.giffgaff.com/orders/affiliate/s3cr3t
Offline Rhyso
Re: quick question
« Reply #1 on: 29 May 2011, 12:18 »
sounds like you knocked the wiring going into the brake pad; make sure the plug is plugged in
Offline bullzeye
Re: quick question
« Reply #2 on: 29 May 2011, 13:02 »
just took the wheels off , checked all wires, the pads are fine plenty on them, but the light is still on, its the circle light with lines around it and trip computer says "check brake pads" just seems abit of coinsidence that this light only started coming on after i removed the wheels
Offline Rhyso
Re: Check brake pads warning light
« Reply #3 on: 29 May 2011, 15:41 »
Check for continuity in the wires themselves; more often then not they chafe and come apart
« Reply #4 on: 29 May 2011, 21:17 »
Push the brake pedal a couple of times and see if it goes if not you may have a break in the wiring.
