Author Topic: dogdy cold running diigifant  (Read 1920 times)
Offline mk1 formel e
« on: 01 April 2005, 22:31 »
my transporter van (2.0l petrol) has decided to idle very rough and stall when cold, it's absolutlly fine once run for a couple of minutes but i cant figure it out as i've never fiddled with digifant before, i've checked the isv and that's fine, now i'm stuffed  anyone got any ideas?
Veedubgt18v
Re: dogdy cold running diigifant
« Reply #1 on: 02 April 2005, 16:24 »
yeah may be the blue temp sender plug on the water housing on the froint of the block, this tells the ecu the engine temp they are about 15 quid from vw, also check for splits/leaks/missing pipes in the vacuum circuits and the pleated throttle body pipe
ed
« Reply #2 on: 14 April 2005, 09:29 »
thanks ed, i'll have a look, after years with k-jet this digifant is a little confusing  :undecided:
Veedubgt18v
« Reply #3 on: 14 April 2005, 22:57 »
coolio! let us know how you get on i will continue to give it thought!
ed
Offline tianaroja
« Reply #4 on: 14 April 2005, 23:08 »
exactly the same problem i have logged on forum at present with my digifant mk3 gti 8vi am going to change temp sensor at weekend after that it could be cold start valve it is a bit dearer though
so many sensors and electronics!! it was easier with a choke which worked when you pulled the cable
Veedubgt18v
« Reply #5 on: 14 April 2005, 23:31 »
except that choke was normally connected to a pierburg carb........not so good!
or even worse and 'automatic' choke!
automatic at staying on!  :shocked:
Offline tianaroja
« Reply #6 on: 15 April 2005, 19:42 »
the most reliable was on my scooter an oversize dellorto with a big bell mouth on you put your hand over it to start it in winter when warmer a peice rag was more technical!!
