Author Topic: engine has started to smoke  (Read 1515 times)
Offline cbr337
« on: 28 May 2011, 20:14 »
Hi all my gti turbo has decided to start puffing smoke out it only does it if you leave it on idle and then blip the throttle and it does a little puff then disapears its blue in colour so its got to be oil burning its not the turbo as ive had it changed thinking it was that causing the problem does anyone have any ides cheers chris
Offline andc1
Re: engine has started to smoke
« Reply #1 on: 28 May 2011, 20:43 »
could be piston rings mate, where in west sussex r u?
Offline cbr337
« Reply #2 on: 28 May 2011, 20:51 »
near chichester, dont say that i was dreading that reply was hoping some else was wrong lol
« Reply #3 on: 28 May 2011, 20:51 »
Might still be your turbo seals.
Offline cbr337
« Reply #4 on: 28 May 2011, 20:53 »
well it was a brand new turbo not recon etc
« Reply #5 on: 28 May 2011, 20:54 »
Remove the inlet pipes and see if you have any oil in them
« Last Edit: 28 May 2011, 20:57 by Wayne »
Offline cbr337
« Reply #6 on: 28 May 2011, 20:59 »
yer not hardly any oil in the pipes at all, it dont smoke when you drive its only when you get to a junction etc and sit there in idle for a bit the blip the throttle and the a puff comes out the ie you pull away its fine even on boost
« Reply #7 on: 28 May 2011, 21:05 »
Could be you valve stem seals
Offline cbr337
« Reply #8 on: 28 May 2011, 21:08 »
id rather it be the stem seals than the rings gone,but are they seals or are they just guides???
« Reply #9 on: 28 May 2011, 21:09 »
You will have valve stem seals.
