Author Topic: Alrite People, newbie here!  (Read 1086 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
« on: 01 April 2005, 19:12 »
just brought a 91 golf ryder!! nice car, problem is i cant get my stero to work, i went 2 halfords thinking i needed an ISO connector and they didnt have any then i went sum where else and they sed i didnt need one, whos rite becuse it didnt work when i just plugged it straight in! :smiley:
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
Re: Alrite People, newbie here!
« Reply #1 on: 02 April 2005, 12:00 »
Hiya!
Try checking the connections on both sides (stereo loom and car loom) for the power connection plug. Make sure that the pins match up with each other, i.e. Power cable in car loom is being connected to power cable on stereo etc. If they aren't you may need to reconfigure the plugs by removing and reinserting the pins. Another thing is that as far as I am aware there is no switchable power supply to the stereo from the car loom. (This is the yellow? cable that should plug into the stereo.) This is solved by connecting the switchable power supply wire from the stereo into the constant power wire (red). This means that you should have 2 constant power wires from the cars loom going into the stereos constant power and switchable power wires. Look for a plug that has a spare socket to it on the constant (red) wire and plug in the switchable wire.
I hope this makes some sense and that my memory has served me right!!  :undecided:
Offline capoot
« Reply #2 on: 02 April 2005, 13:13 »
sorted!! thnx!  :grin:
