Author Topic: Brakes - Crap and spongey as f*ck  (Read 2737 times)
Offline bobbarley
  • I'm kind of a big deal...
« on: 26 May 2011, 21:02 »
Okay dokey, brakes have been rubbish for a while now, and I really need to get them sorted out.  There's a lot of travel on the brakes when the pedal is pushed, well over half way until they come on.  When they do engage there's no bite like on standard mk4 brakes.  Rears are totally standard, fronts are upgraded 312mm's with EBC discs and pads.  I had the fluid changed last year by VW.  I've checked and there's no leaking.  When I slam the brake pedal hard and quickly it sounds like air wheezing out.
I'm not sure what else it could be so am open to suggestions?  Brake cylinder or something (don't know what I'm talking about) maybe?  :undecided:
Offline new to vw
Re: Brakes - Crap and spongey as f*ck
« Reply #1 on: 26 May 2011, 21:34 »
Check the cap and the rubber seal on it on the brake master cylinder..
5 door 1.8t AUM
Offline bobbarley
« Reply #2 on: 26 May 2011, 23:06 »
Assuming to check the master cylinder I'm going to have to take it out and remove all the brake fluid?  :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 27 May 2011, 00:02 »
have you re-bled them mate.. maybe try bleeding the master cylinder as most people when changing fluid on the mk4 blled the callipers and not the master cylinder which 'must' be bled or you will get crappy spongey peddle
Offline bobbarley
« Reply #4 on: 27 May 2011, 08:18 »
Sounds complicated!
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 27 May 2011, 09:28 »
Don't be a tart lol
Offline nadlad
  • Building Surveyor MRICS
« Reply #6 on: 27 May 2011, 11:56 »
use a ezi bleed start from the back left, back righ,t front passenge,r front drivers and then do the cylinder last.
when i did mine theres two valves on the cylinder and for the amount fo time it take to take the rubber hose off and tighten the nut up i wudnt worry about air getting in.
alternatively use vag com and it will turn the abs pump and  push all the air to the master cylinder
ezi bleed ftw
<<<Big Build Thread>>>
Offline houston
« Reply #7 on: 27 May 2011, 12:01 »
if it was bled last year by vw then id say it was done right last time. have you been checking your fluid levels?
Offline Steve_PD
« Reply #8 on: 27 May 2011, 12:27 »
Offline johnson6672
« Reply #9 on: 28 May 2011, 13:00 »
Ezee bleed all the way i had dramas with mine and steve pd's cars when bleeding the brakes, now got ezzee bleed and is simple just follow the guide in the maint section.
Although does sound dodgy do you know how to check the servo?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
