Author Topic: Brakes - Crap and spongey as f*ck  (Read 2743 times)
Offline bobbarley
  • I'm kind of a big deal...
Re: Brakes - Crap and spongey as f*ck
« Reply #10 on: 28 May 2011, 13:13 »
The guide in the maintenance section might as well have been written in Arabic, and the pictures are completely useless!  :grin:
Fluid levels are fine.
Offline johnson6672
« Reply #11 on: 28 May 2011, 13:21 »
What about the servo?
MK4 GTI T AGU, REVO Remap, BMC carbon box, Miltek cat back, Forge diverter valve, THS FR3 engine/Gbox mounts, Some random alloys, lowered on coilovers.
192bhp 212lbft torque.
Offline bobbarley
« Reply #12 on: 28 May 2011, 13:54 »
I don't even know a servo is  :grin:
Offline johnson6672
« Reply #13 on: 28 May 2011, 14:22 »
Its the bit that assists the master cylinder in appyling your breaks, if i remeber correctly with the engine off apply the break, start the engine and the peddle should drop a little, if it goes to the floor theres a problem, i think thats the correct sequence anyway
Offline bobbarley
« Reply #14 on: 28 May 2011, 14:26 »
Ahh I seeeee.  Thanks I'll give it a try, no harm in it!
Offline vw-8v
« Reply #15 on: 28 May 2011, 14:29 »
servo is the big round bowl looking part on the bulk head behind master cylinder but b4 you start replacing parts(like i did) i would redo the bleeding as previously said master cylinder last if u don't want to do it i think my local garage charged 35 quid. if no joy then take it from there.
Offline bobbarley
« Reply #16 on: 28 May 2011, 18:01 »
Tried it.  Pedal drops all the way to the floor  :sad:
Offline richw911
« Reply #17 on: 28 May 2011, 21:48 »
Take it to vw get the fluid changed and they will bleed it properly job done  :cool:
IIRC it costs £35  :undecided:
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #18 on: 29 May 2011, 09:11 »
£45 at mine  :smiley:
« Reply #19 on: 29 May 2011, 21:26 »
This, they are not easy to bleed.
