Author Topic: central locking  (Read 1285 times)
Offline mattyb12345
central locking
« on: 24 May 2011, 11:16 »
not long just brought my first car p reg mark 3 gti 8v.. am i supposed to have central locking? because mines not working if i am? thanks matt.
mattyb
Offline Kerrse
Re: central locking
« Reply #1 on: 24 May 2011, 11:43 »
Fairly easy to tell your keys would have a locking button on them
Offline trog_nfs
Re: central locking
« Reply #2 on: 24 May 2011, 11:47 »
Nah, it a mk3, remote central locking was a dealer fit option only.
Have a look in the mk3 section, its a common problem for the central locking to not work.
1. Check you have a pump, its in a box under the drivers side taillight.
2. Check fuse 21.
3. Listen for pump whirring when you turn the key.
4. Check for breaks or leaks in the pipes between all the doors.
There's a few places for you to start. The list is almost endless. Try using the search.
Offline mattyb12345
Re: central locking
« Reply #3 on: 24 May 2011, 11:55 »
cheers trog big help
mattyb
Re: central locking
« Reply #4 on: 24 May 2011, 23:50 »
Pump failure is common or pipe broken somewhere.
