Author Topic: cant get any rear sound?  (Read 2134 times)
Offline liamwitz
« on: 23 May 2011, 21:21 »
hi i have never done car audio before, done alot of home audio and what not but i guess the speakers are different, if im being stupid just tell me how i do get rear audio ahha
basically im trying to connect my speakers to the radio, it was fitted before i got the car and front speakers work but rear dont, well rear arent even fitted but thats what i am intending to do.
Offline dragonfly
Re: cant get any rear sound?
« Reply #1 on: 24 May 2011, 18:18 »
Those look like RCA connectors for an external amp.  Do you have an ISO block at the rear of the unit?
Offline Len
« Reply #2 on: 25 May 2011, 09:43 »
Have you actually checked you have speakers in the rear?
www.sas.org.uk
www.the-ace.org.uk
Offline N900 MJT
« Reply #3 on: 25 May 2011, 16:17 »
Ok well first this is to fit rear speakers - then you have 2 options -
1 - run them from the headunit using the standard wiring, easy job just make sure the wires are in nice and securely
2 - Run an amp to drive all 4 'in car' speakers - little bit more work but the sound will be much better
With an external amp driving your speakers you will be able to get full power but this does involve buying an amp, power cable, earth cable and i would recommend getting some half decent speaker cable.
Im currently running some of this in my car - http://www.chord.co.uk/products.php?pg=56 - and it sounds fantastic!
