Author Topic: induction kit fitting  (Read 2968 times)
Offline yellowconcept
  • fezzy cruiser
« on: 31 March 2005, 20:43 »
hi all, im stuck on fitting a really simple k&n air filter ive removed the standard air box and bought a conversion plate to go from a square hole to a round hole, i have connected it all up and it sounds mint really beefy but when i thrash it the engines trying to cut out and die down ??, now there was 3 connectors which plug in 1 goes to the top of the box 1 to the right hand side front and the other1 into a little box thing by the air box, with not having the standard air box on anymore is it playing up because theres no where for the connector to plug in?? thanks for your help lads
A. Cooper
Offline Overseer
Re: induction kit fitting
« Reply #1 on: 31 March 2005, 21:36 »
you're talking about the MAF?
  • fezzy cruiser
« Reply #2 on: 31 March 2005, 21:43 »
im a bit thik here m8 what is the maf ?? the 1 i cant connect is the 1 that plugs into the edge of the standard box itself opposite the fan belts by the front of the car ? when i put it all back standard it runs mint?
A. Cooper
Offline Overseer
« Reply #3 on: 31 March 2005, 21:56 »
ok.. i;m pretty sure its the MAF..  Mass Air Flow sensor.
did the instructions that came with the kit say anything about what to do with the connector?
anyone... i've only ever installed an induction kit.. on my old '96 polo.. which just sat directly ont he throttle butterfly.. and on a saxo.. which was a similar arrangement but with some pipe to extend it somewhat
« Last Edit: 31 March 2005, 21:59 by Overseer »
  • fezzy cruiser
« Reply #4 on: 31 March 2005, 22:01 »
ive got it here in front of me and it just says it stays disconnected ?
A. Cooper
Offline Overseer
« Reply #5 on: 31 March 2005, 22:09 »
ok.. i know on some cars the MAF still gets used..
whats all this conversion plate/round hole/square hole business?
in my experience induction kits normally come with all the necessary parts?
at which point are you saying the engine is trying to cut out?
when you stompy your foot down.. or after you've revved the tits off it?
i found on my polo the induction kit added lag when accelerating, and made it more tricky.. it was more likely to stall unless you gave it more gas.. and talking of gas.. i took it off as it drank so much!
(nearly was much as this valver i upgraded to.. LOL!)
  • fezzy cruiser
« Reply #6 on: 31 March 2005, 23:03 »
hello again the conversion plaTE converts the square end on the air box to round so u can put a filter on with a round end
A. Cooper
Offline Overseer
« Reply #7 on: 01 April 2005, 10:06 »
yeah i understand that.. what i dont get is why you make it sond like it didnt come with the kit in the first place?
  • fezzy cruiser
« Reply #8 on: 01 April 2005, 12:49 »
ive just looked at it and its now running mint no cutting out or dying down thanks for the help lads
« Last Edit: 01 April 2005, 13:26 by yellowconcept »
A. Cooper
