Author Topic: Fog Light symbol on clocks is lighting up faintly when I press the brakes??  (Read 1413 times)
Offline The Dave
Hi guys. Odd little problem... just recently noticed my rear fog light symbol on the clocks is lighting up when I press the brakes. I notice it more with the lights on at night so the clocks are illuminated... but does it all the time, just can't see it in daylight. It lights the rear fog light symbol up just faintly and a bit flickery.
(Really crap) Video of what I mean:
http://www.youtube.com/watch?v=YzRMPn9ma7k
Any ideas? :)
Thanks.
Offline Granta Gti
it sounds like your stop lamps are not earthed properly and are earthing through the fog lamp, meaning a little bit of current is passing through them, enough just to illuminate the symbol a little.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
I'd say earth too, have a good check to see if anything is up with the wiring around the light area in the boot
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
+1 check rear light clusters and poss clean tracks.one of mine was slightly corroded and bridging slightly onto next track i cleaned and used wd40 on it and still all good a year on.
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline vw-8v
had exact same prob when i changed my standard  rear lights over to gti ones and it was down to the lighting board/holder off the the replacement ones so just used the old clean non corroded one and it went bk to normal.
Offline The Dave
Yep I have some corrosion going on.
I checked the passenger side rear light and it had a little bit of rust on the connections but nothing too bad, then went to check the drivers side and couldnt get the connector off, so left it...then was told none of my lights worked on that side. Oops!
So I persevered and got the connector off and it's pretty rusty, I need to get it cleaned up somehow today and will WD40 it aswell.
Can I use anti-rust spray on it or best to try and clean with some kinda sandpaper then WD it? I had to put the connector back on as wasn't at home and it was at night but alas after some wiggling to make it work the fog light symbol hasn't come on so it'll definitely be that.
Thanks guys :)
