Author Topic: delock question  (Read 1474 times)
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
delock question
« on: 20 May 2011, 21:56 »
Seen the how to guide etc my question is this does anybody know wot the little metal disk  does and why do you need it?thanks
« Last Edit: 20 May 2011, 21:59 by symsymma »
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline andc1
Re: delock question
« Reply #1 on: 20 May 2011, 22:14 »
blocks off the hole the original lock piece sits in and turns, without promoting how to break into your car you need these disc, vw do them under METALDISC not on etka system tho when you go in and ask
Offline symsymma
Re: delock question
« Reply #2 on: 20 May 2011, 22:21 »
Ok i get it edited cos im an idiot :smiley:
« Last Edit: 20 May 2011, 22:33 by symsymma »
Offline andc1
Re: delock question
« Reply #3 on: 20 May 2011, 22:27 »
pm'd you
Offline richw911
Re: delock question
« Reply #4 on: 21 May 2011, 20:48 »
As said MAKE sure you fit the metal discs  :smiley:
Offline symsymma
Re: delock question
« Reply #5 on: 21 May 2011, 21:57 »
yea mate will do for sure the pennys totally dropped on this issue,silly bloody design flaw really on vw's part.just gotta get disks and spray caps and im ready to roll :smiley:
Offline Dave_IOW
Re: delock question
« Reply #6 on: 22 May 2011, 11:54 »
What happens if your battery goes flat with the doors locked though?   :huh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline andc1
Re: delock question
« Reply #7 on: 22 May 2011, 12:01 »
unlock the boot  :grin:
Offline symsymma
Re: delock question
« Reply #8 on: 22 May 2011, 12:33 »
yea boot acess only.already thought of that failing that a brick. :grin: :grin: :grin:
Offline Dave_IOW
Re: delock question
« Reply #9 on: 22 May 2011, 14:35 »
Good call
