Author Topic: Possible Problemo  (Read 1690 times)
Offline dom
  • Back in a Mk4
Possible Problemo
« on: 18 May 2011, 19:27 »
Ok, so have been getting a knocking noise from the front end recently and haven't really investigated it yet but was looking under the bonnet and saw this:
What is that behind the CV boot? A mount of some sort? Gearbox? Also should it be leaking like that?
Offline Dan_GTi8v
Re: Possible Problemo
« Reply #1 on: 18 May 2011, 19:30 »
looks like the gearbox mount, theres nothing inside it its just rubber so not sure what it could be? Maybe something dripping onto it?
Offline AndyMk3
« Reply #2 on: 18 May 2011, 19:34 »
gearbox mount matey if you need one got plenty of mint ones
VW BUSH
« Reply #3 on: 18 May 2011, 19:35 »
Probably full of water and muck being pumped out as the engine wiggles.
I have seen oil filled mounts but not on a mk3........
When gone this will give you noise and vibration which is very annoying, mines buggered too  :angry:
Front one is probably gone too just like mine :grin:
Offline dom
  • Back in a Mk4
« Reply #4 on: 18 May 2011, 19:47 »
Cheers guys, so the consensus is that the gearbox mount is knackered? Is that likely to be causing knocking though? I'm also guessing that it is a sod to replace?
VW BUSH
« Reply #5 on: 18 May 2011, 19:51 »
It does cause knocking, but do check the front mount as the new one wont last long if its f'ed.
Only the rear is a bugger to do, fronts can be done in a couple of hours with a jack and a good set of sockets and spanners :wink:
Offline dom
  • Back in a Mk4
« Reply #6 on: 18 May 2011, 19:56 »
Cheers, I'll have a good look at the front as well :afro:
Offline golf newbie
« Reply #7 on: 18 May 2011, 20:10 »
My gearbox mount looked the same with grease coming out of it.
Offline dom
  • Back in a Mk4
« Reply #8 on: 18 May 2011, 20:15 »
One more thing, is it worth buying genuine?
Offline wrobstar21
« Reply #9 on: 18 May 2011, 20:16 »
Hydraulic gearbox mount, just had to replace mine. 15 quid from gsf.
