Golf mk3
hardmonkeys
Possible Problemo
Topic: Possible Problemo (Read 1692 times)
wrobstar21
GTI forum regular
Re: Possible Problemo
Reply #10 on:
18 May 2011, 20:19 »
And there is a guide for it somewhere. I sheared the bolt though getting it off and had to get a bolt from a dealer, 2 quid!
Wayne
Sir Postalot
Reply #11 on:
18 May 2011, 23:37 »
The mount is hydraulic so if it is leaking then it is knackered.
thai-wronghorse
Serious forum addict
mk1 Seat Leon FR TDI
Reply #12 on:
19 May 2011, 00:51 »
As I mentioned in your other thread, the gearbox mount is really easy to change and the front engine mount isn't much harder. Only the rear engine mount is a fiddly f**k*r to get access to undo the bolts.
Rmachines
Passat 20vT Estate and Candy White MK3 1.8 GL
Reply #13 on:
19 May 2011, 12:30 »
Yea these rear mounts are full of oil, that one is simple to change, just jack it up, unbolt the top bracket and swap.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Golf mk3
hardmonkeys
Possible Problemo
