Author Topic: steering wheel spline addaptor question?  (Read 1149 times)
Offline aaron1980
« on: 17 May 2011, 21:31 »
Hi my golf came with a halfords special of a steering wheel fitted and i wanted to change it back to standard (i got one from the brakers) it was a later steering wheel so had a larger spline i have managed to get the spline addaptor but now i have fitted it im left with a gap between the rear of the steering wheel and the cowling as if the steering wheel is not pushed on far enough? has anyone else had this problem or do i need to change anything else to get it to fit propaly? :sad:
Offline Simeon
Re: steering wheel spline addaptor question?
« Reply #1 on: 22 May 2011, 01:12 »
Are you fitting it to an early car?
Presume you have tightened the nut right up to push wheel on as far as it will go?
Offline aaron1980
« Reply #2 on: 24 May 2011, 18:53 »
Yes I was trying to fit it to an early car but I have given up now lol. When I took the old steering wheel off there was a spring that Is held on with a small metal ring when I try to fit the new steering wheel the spring can't compress enough so stops the new wheel from fitting??
