Author Topic: Purge valve needed?  (Read 2389 times)
Offline liva2704
Purge valve needed?
« on: 16 May 2011, 11:00 »
I am going to remove my charcoal canister and was wondering if its ok to remove the purge valve that is connected to it?
Offline Benrevs
Re: Purge valve needed?
« Reply #1 on: 16 May 2011, 12:13 »
You can take it off, just plug the intake end.
Offline liva2704
« Reply #2 on: 16 May 2011, 13:05 »
Cool thanks yet more useless junk i can bin lol
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #3 on: 16 May 2011, 20:44 »
Is the purge valve the unit to the left of the air box?
« Reply #4 on: 20 May 2011, 07:25 »
Anyone?  :undecided:
Offline javalin
« Reply #5 on: 20 May 2011, 10:21 »
purge valve is on the suspension turret on the drivers side, next to the air box.  charcol canister in the o/s/f wing below and down a bit from the airbox.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
« Reply #6 on: 20 May 2011, 11:02 »
Cool, exactly as i thought. ta
« Reply #7 on: 10 June 2011, 00:21 »
I was looking at this earlier whilst the engine was running and noticed that it sounded almost tappity.
Is this how they're supposed to sound?
Like the original poster, I was also considering the removal of my carbon canister and purge valve but was wondering what exactly what to do with all the pipes and cables that run to them.
Which ones needed to be joined, blocked or removed?also what happens to the the two electrical connector blocks - one on the top of the purge valve and the other on the sensor that is inside the air filter box?
Will disconnection of any of these affect running at all? Do any of the fuel vapour pipes need mini gauze filters attached to them?
Offline marky-gee
« Reply #8 on: 10 June 2011, 15:16 »
Intrestesting, removal I like.
1997 GOLF GTI 2.0 (8v)
« Reply #9 on: 10 June 2011, 21:10 »
Just bin it.  :smiley:
