Author Topic: Car is reving it self and somtimes jams at 2.000 rmp  (Read 3432 times)
Offline mani12354
Re: Car is reving it self and somtimes jams at 2.000 rmp
« Reply #20 on: 13 June 2011, 16:19 »
Does anyone know what this problem is?????????? :laugh: im going crazt  :shocked:
Offline justalex81
« Reply #21 on: 13 June 2011, 16:24 »
so you've checked the vacuum pipe that goes from the inlet manifold to the ecu. mine perished the otherside of the bulkhead just before the ecu and was doing exactly what you're describing. you can't see it unless you remove the scuttle panel.
Offline mani12354
« Reply #22 on: 13 June 2011, 16:27 »
i always check that and still i get the same issue
Offline Screech16v
  • MK3 20vt AGU
« Reply #23 on: 13 June 2011, 20:12 »
Take the intake pipe off and press the butterfly closed with your finger whilst engine is running.
Offline mani12354
« Reply #24 on: 13 June 2011, 20:31 »
oki now my car keeps geting stuck at 2.000 rpm i just drove :|
Offline iyrix
« Reply #25 on: 13 June 2011, 20:38 »
What size is this pipe?  Just want to order some to replace.
Golf GTI 16v
« Reply #26 on: 13 June 2011, 23:49 »
Check and see if the throttle linkage or cable is sticking.
Offline mani12354
« Reply #27 on: 13 June 2011, 23:52 »
i noticed the pedal moves up and has alot of play init the cable could be sticking isit easy to change]
« Reply #28 on: 13 June 2011, 23:59 »
Yes very easy to replace :smiley:
Offline mani12354
« Reply #29 on: 14 June 2011, 00:02 »
 :shocked: can you tell me a short tutorial  :rolleyes:
