Author Topic: forge 007 spring  (Read 3319 times)
Offline paulturbo
forge 007 spring
« on: 14 May 2011, 11:46 »
Standard ecu with a forge 007p the spring inside in painted green although its wearing off,is this correct?
Offline porter_89
Re: forge 007 spring
« Reply #1 on: 14 May 2011, 11:47 »
yea the green should be and i might be wrong good for 8-10psi yellow is stage 1 blue after and red is race spec
cheers
1.8t-aum-stage 1 remap wagen worx-CAI-demon motorsport TIP-black forge 007P,H.I.D's 6000k-front badgless bonnet bra-r32 reps(selling soon)-m3 rear lights,dropped on JOM coilovers with fk drop links-3" turbo back exhaust-FMIC ordered SOLD SOLD SOLD
to do:
Bbs lm reps want now haha r32 wheels for sale soon pm me if interested
Offline mr 1.8t dubbster
« Reply #2 on: 14 May 2011, 12:18 »
+1 on that!
Forge Splitter, Smothed Airbox, Re-map and coilovers next.
Offline porter_89
« Reply #3 on: 14 May 2011, 12:20 »
would blue be k04-001 with remap
to do:
« Reply #4 on: 14 May 2011, 12:29 »
this is the guide from forge motorsport, hope this helps, you will need to know what psi you are running.
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
The above figures are estimates only and should only be considered as a guideline
Offline s-l-i-x
  • Golf MK4 1.8T AGU
« Reply #5 on: 14 May 2011, 17:52 »
Im running the yellow on my standard remapped 1.8T. Tried the green and yellow but found the yellow was better  :smiley:
Offline Dave_IOW
« Reply #6 on: 14 May 2011, 17:56 »
i got red. stage 1 ko3 map but running with ko3s, a red spring opens by itself at 18psi  :smiley:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline paulturbo
« Reply #7 on: 16 May 2011, 08:23 »
Ok,well this is my theory...when I bought my golf it had crappy purple dump valve on which I thought needed replacing,so I did with a forge with a green spring.however around this time my car started flat spotting at full boost when driven hard.I am now wondering wehter the car has had a remap in the past and reuqires the yellow spring?thought I'd just buy one and try it?thing is I have no idea what a standard and non standard 1.8t is supposed to drive like.lol.
Offline porter_89
« Reply #8 on: 16 May 2011, 10:18 »
what's it boostin mate anythin over 12 And its had a remap
to do:
Offline Big Tone
« Reply #9 on: 16 May 2011, 10:29 »
I use yellow +1 spacer, I tried several different combinations and found this to build boost a little slower, but it felt bigger and it held alot better than without.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
