Author Topic: Oil pump drive  (Read 2281 times)
Offline CM690
  • Golf MK4
Oil pump drive
« on: 13 May 2011, 08:01 »
Is the oil pump on a mk3 chain driven?  How hard would you say it would be to change an oil pump? Relatively straight forward or does this need to go to a garage :o
Does anyone know where I could pick a pump up? My engine code is AEX but I can't seem to find the part anywhere :/ cheers guys!
Offline Ess_Three
Re: Oil pump drive
« Reply #1 on: 13 May 2011, 11:48 »
Oil pump is driven off the intermediate shaft, which is driven by the cambelt.
To change the oil pump, sump off, two bolts out, pull downwards...reverse sequence for fitting the new one. That's it.
(assuming the AEX is the same as all other VW small block and tall block 4 cylinder engines)
..but gaining motorcycles.
Re: Oil pump drive
« Reply #2 on: 13 May 2011, 12:14 »
Just checked and it is chain driven
Oil filter / oil pump / 1.4/1.6 ltr. / AEX,AEE
1 = 032115105G
Offline Ess_Three
Re: Oil pump drive
« Reply #3 on: 13 May 2011, 14:27 »
1 = 032115105G
That'll teach me!
Is the AEX the little 16v like the Lupo GTI uses?
Re: Oil pump drive
« Reply #4 on: 13 May 2011, 15:14 »
1 = 032115105G
That'll teach me!
I am not sure, I believe it is a 8v  :undecided:
Offline CM690
  • Golf MK4
Re: Oil pump drive
« Reply #5 on: 13 May 2011, 15:27 »
The AEX engine is an 8v :p does the cam belt have to come off for this? :confused:
Offline leigh_harty
  • Audi AGU
Re: Oil pump drive
« Reply #6 on: 13 May 2011, 16:52 »
1 = 032115105G
That'll teach me!
Is he not reffering to the block?
Dont lose your dinosaur!
