Author Topic: Small turbo Mk4 Golf GTI tuning another way  (Read 23241 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« on: 12 May 2011, 22:23 »
Just thought I would give you guys an update on my Mk4 AUM since my oil pump failed and shot number1 rod through the side of the engine... :grin:
Second hand block fitted from a 80k AUM fully stripped and rebuilt with h-beam steel rods from THS performance, new oil pump, oil pick up pipe and S3 BAM harder big end bearings.
Still running the K04-001 turbo, oem maf, 386cc injectors with THS FMIC and large bore Milltek turbo exhaust, but now with ported exhaust manifold, reduced collector and over sized runner port 3.
Around 100 hours fine tuning and mapping time managed to pull 334lbft 233bhp.  Due to having the stronger rods I went all out on the torque mapping, which caused peak bhp losses due to flow and turbo VE, BUT.... the car holds a flat 230bhp from 3300rpm to 5300rpm which makes the average much power MORE than a full spec stage2 LCR running 280bhp. :smug:   With launch control the car will pull 0-60 in 4.5sec and 0-100 in 11.5s.
NOW  The the fun part.. since we have become a NOS refil station and Wizard of NOS dealer I decided to fit a 200bhp+ wet not kit to the old girl.. :laugh: which means detuning the map to 270lbft to get some peak bhp back and reduce the peak cylinder pressues and pull 3.25 degrees of timing out, it is now closer to 250bhp with the turbo running 95% at the top end.
We fitted the NOS nozzles with the 50shot jets and managed a dyno pull on NOS of 288bhp 308lbft during testing and setting the noz, at this point the idea of getting to 300bhp+ was cut short due the fuel pump hitting its hard limit. Plus the amount of timing pull was was seeing with nos on peak torque was around 10-11cf which I was not happy with, and did not want to pull any more timing back as this would cause higher EGT  and lost effichency.
SO new in tank fuel pump pushing 225lph and a custom modded swirl pot fitted, this should see me well over 400bhp.
The next problem was charge cooling and keeping the ignition pull down to 5-6cf the only answer to this was a progressive injection of water &alcohol (methonal) mix direct into the inlet manifold next to the AIT sensor.
Next stage is to finish the mapping, and dial in the ratios for the NOS and 100shot jets with water meth injection, then fingers crossed 330bhp+ 380lbft and a 12s  1/4mile.
I will get some pic up tomorrow
 01455 617233
Offline Grand Master Patch
Re: Small turbo Mk4 Golf GTI tuning another way
« Reply #1 on: 12 May 2011, 22:31 »
0-60 in 4.5 :shocked:
Keep up the work Nick :evil:
Offline Granta Gti
« Reply #2 on: 12 May 2011, 22:31 »
Pretty mental  :laugh: wander what it's quarter mile time is !
Offline bobbieboy69er
  • MK4 1.8T AUM
« Reply #3 on: 12 May 2011, 22:41 »
Nice!!  Good to see you in the forum again nick!
MK4 1.8T AUM|30mm Eibach Springs|Milltek cat back|4mo rear valance|pipercross filter|R-tech Stage 1 Remap|Baileys DV|Powerflex Front and Rear Bushes|312mm Front Brakes|Creation Motorsport TIP and hoses|17" TT Ronals|  220BHP
Offline RTechUK
« Reply #4 on: 12 May 2011, 23:28 »
Last summer with just the stock engine, k04-001, FMIC, Forge TIP and Milltek back and around 250bhp 250lbft@3000rpm it ran a 13.8s @103mph on stock rims and goodyear rubber, full interior, full tank of fuel, baby seat and tools. :grin:  The car feels twicw as qucik in the midrange now
Its very very nippy all the power on tap between 2900rpm and 5500rpm, but still pull strong to the 8000rpm limiter which when shifting up ther gear at around 7800rpm land the rpm in the sweet spot of the torque band for the next gear.   80mph in 2nd gear, 125mph in 3rd and 152mph in 4th at 8k.
 01455 617233
« Reply #5 on: 12 May 2011, 23:55 »
Awesome, looking forward to the pics. :cool:
Offline daz veedub
  • Operation 1.8t bolf
« Reply #6 on: 13 May 2011, 12:23 »
would of loved to see u hit nos butten on the rollers  :cool:
sounds like ur gona have a right machine on ur hands keep up the good work lads  :smiley:
Offline jonnyturbo
« Reply #7 on: 13 May 2011, 15:41 »
Genius at work  :grin:
Offline porter_89
« Reply #8 on: 13 May 2011, 16:17 »
right this ir what Im aiming for ko4-001 Is it worth keeping standard maf also the injectors sab reds? so with all the mods without nos and rods can i hit 250-260 with the ko4.001 and is it custom map cheers
1.8t-aum-stage 1 remap wagen worx-CAI-demon motorsport TIP-black forge 007P,H.I.D's 6000k-front badgless bonnet bra-r32 reps(selling soon)-m3 rear lights,dropped on JOM coilovers with fk drop links-3" turbo back exhaust-FMIC ordered SOLD SOLD SOLD
to do:
Bbs lm reps want now haha r32 wheels for sale soon pm me if interested
Offline RTechUK
« Reply #9 on: 13 May 2011, 17:09 »
Saab reds will be no good for the aum, you will need the inectors from a 225 TT or S3.
With the right mods we will tune your k04-001 to around 265-270lbft 240-245bhp.  The main gains over the k03s is how long the 001 can hold the torque for.  I wont tuned a customer car to the limit i have tuned mine to.
Nick
 01455 617233
